A deal as good as this could turn into a solid year of your life spent rebuilding your car.
Everyone thinks OH for joy. A supra. I think I will buy it.
And then you realize the grass was green over here because it's covered in coolant.
Good Luck. cause, it sounds like they fixed and then drove it until they started thinking it may blow again or we should sell it before it blows.
So does she still sound like a deal??? You take these cars at face value and then tyou have to figure they "the car" is hiding something. Because they do and they do it well.
If you are buying this car because you invision it one day being nice. You are asking for it. You should read everything you can about these cars because more of them get worked on all week long so we can drive them on the weekends, than their are daily drivers.
If you aren't a mechanic yet, you will be when you aquire a supra. Because they cost too much to let someone else work on and you'll be workiing on it enough that you'll have to do the work so you can learn how to work on it yourself. If you are a worthy supraholic.
Good Luck. Make sure it has the stock engine in it. Cause if it's jdm and it breaks, you will be doubley lost if you don't know these engines.
