Got to be info here we can use
http://www.suprastore.com/bolost2notot.html
This is the setup for a na-t mk4 supra its a 525hp setup on the stock mk4 internals.
Here we go non-turbo Supra owners! Turbo power for your non-turbo Supra from Boost Logic. Fits 1993-1998 Supra Non-Turbos (both automatic and manual trans).
Approximate power capability 525hp.
This kit contains everything you need to convert your Non Turbo MKIV Supra or SC300 into a turbo charged sleeper. Here is the list of parts included.
Boost Logic 321SS Tubular Manifold 1 5/8” Tubing and 1/2” Thick 321SS Flanges
(Turbo’s with a 4” inlet clears the distributor.
Manifold fits a turbo up to a T76)
Boost Logic Spec T4 Turbo
HKS 40mm Wastegate
3” SS304 Polished Downpipe w/ Flex Joint
3” SS304 Polished Midpipe
SS304 Polished Dump Tube
3” Polished Aluminum Intake Pipe
Boost Logic Front Mount Intercooler (FMIC) Kit
2 ?” Polished Aluminum IC piping
4 Ply Silicone Hose Connectors
Stainless Steel Hose Clamps
Boost Logic NA-T SS Braided Oil Feed and Return Kit w/
Aeroquip fittings
3” K&N Filter
K&N Breather for PCV Valve
Walbro GSS341 255HP Fuel Pump w/ Install Kit
Stage II Upgrades
Boost Logic 2.5mm Head Gasket
440CC Injectors x 6 (fits in the stock rail)
Injector Piggy Tails x 6
All necessary clamps and bolts for installation
Note. As with all turbo conversion kits installation should be performed by those familiar with turbocharged engines and tuning. Serious engine damage can occur with improper installation or tuning. Consult an expert.
Ok well there has to be something we can learn from this so us non-turbo mk3 owners can get the same amount of hp i know there not the same engines but the internals should be of about the same quality, and we should be able to find the same things, for the 7mgte/7mge motors plz help us non-turbo guys get turbo.
