Thread: Need Help
Old 08-27-2007, 09:04 PM   #2
IHateHacks
IHateHacks's Avatar
Did you reuse or replace the head bolts? If you replaced, did you use ARP? What was the final torque spec on the head bolts? How many passes did you do when you installed the head bolts?
I would get in there ASAP and retorque the head bolts. Sounds like a shoddy install and they loosened up. But that is pure speculation at this point. Report back.
