Originally Posted by IHateHacks
I agree totally. Do it right, do it once. And do it yourself.
As far as the ARP's, I'm a big fan of ARP bolts. Ease of installation with ARP's unsurpassed quality. And unless you are running over 500whp, I don't think ARP studs are needed. Unless you like juggling studs, washers AND nuts all covered in ARP moly lube. I prefer to juggle just bolts and washers. Plus its a tight fit inbetween the lifter bore castings for ARP bolts but it IS possible without machining the castings. I've "HEARD" that studs DO fit without removing the block from the engine bay but I've never used studs on a supra so I can not verify. I can only verify that bolts fit without any problems, it was actually fun installing the head bolts!!
So you're saying you have ARP bolts, not studs with seperate nuts?
I wasn't given a choice but maybe I can exchange the stud/nut set I have for just bolts. Would be much easier.
