HG repair :(
ok so will all these items set me up for HG repair
http://www.suprasport.com/Head-Gaske...p_253-693.html
plus the timing belt tensioner
and a good machinist
what i thought i was clear of is coming back and i think its now obvious that its the HG.
and also is there any other things i should do while the engine is out, i wanna get rid of the EGR system. and does anyone know can they machine the block while its in the bay?
7MGTE - 500hp  never dyno'd
fidenza cam gears
