Pull the thermostat housing and upper timing cover and make sure the cam marks line up when the crank pulley is lined up with the 0 degree mark. It will only line up once every 2 times you spin the crank.
Did you replace or reuse the timing belt? Did you replace or reuse the tensioner? What did you torque the tensioner bolt to? Did you properly tension the timing belt?
