Oil Pan Leaking!
I finished my turbo swap about three months ago and so far everything is great. However, my oil pan is leaking out the front end. I have taken it off and tried to re do it three times. The next will be the forth. The first and second times I used fel-pro gaskets and copper rtv hi-temp silicone. The last time (after consulting the toyota dealer) I used the black toyota fipg. Still no luck is there some trick I should be doing? HELP please!! This leak is driving me crazy, not to metion gumming up my once clean undercarriage.
Thanks
