Did you check to see if the flange was flat like it is supposed to be. A little bent spot will cause it to leak like crazy no matter how much you try to seal it. The reason is when you tighten it down it will pull away from the RTV and leak. Also I would check to make sure there isnt a crack somewhere. Because if you filling it with a ton of RTV and it is still leaking that seems to be a big flag to me.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
