i think its the same since its the same block, and i checked an auto parts store like autozone and na and turbo had the same part numbers so yeah i guess the clutch and flywheel are the same, the 1jz flywheel is different for sure cause it has 8 instead of 6 bolts
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
