Fit the cylinder head onto the dowel pins in the block. Then take the washers and drop them over the head bolt holes. Next take the allen head wrench that came with your ARP stud kit and thread the studs into the block with the allen head wrench, DO NOT TORQUE THE STUDS WITH THE ALLEN WRENCH. The allen wrench is ONLY to install the studs, not to torque them. Then take the nuts and carefully thread them on. Don't forget to liberally coat all threads with ARP moly lube. Use 5 separate passes to work up to your final torque value. Make sure all head bolt threads in the cylinder block are spotless, any dirt, debris or liquid will throw torque values off significantly.
