Old 09-01-2007, 12:56 PM   #194
Spudboy
Spudboy's Avatar
Originally Posted by IHateHacks
Fit the cylinder head onto the dowel pins in the block. Then take the washers and drop them over the head bolt holes. Next take the allen head wrench that came with your ARP stud kit and thread the studs into the block with the allen head wrench, DO NOT TORQUE THE STUDS WITH THE ALLEN WRENCH. The allen wrench is ONLY to install the studs, not to torque them. Then take the nuts and carefully thread them on. Don't forget to liberally coat all threads with ARP moly lube. Use 5 separate passes to work up to your final torque value. Make sure all head bolt threads in the cylinder block are spotless, any dirt, debris or liquid will throw torque values off significantly.
That sounds swell IF my studs had any hex or way to get an allen or any other kind of wrench on them. They don't. They are just studs...threaded on both ends just like your factory exhaust manifold studs, et al.
I'll keep ya'al posted if (when) I figure something out.
