Originally Posted by Spudboy
That sounds swell IF my studs had any hex or way to get an allen or any other kind of wrench on them. They don't. They are just studs...threaded on both ends just like your factory exhaust manifold studs, et al.
I'll keep ya'al posted if (when) I figure something out.
MY BAD...There is a 5mm allen hex on one side. I was wanting to install upside down as the thread depth seemed to match the original bolts that way. Maybe the ARP studs are slightly different to accommodate the thicker MLS gasket?
I hope so. If not I wont get high enough torque. I better trust ARP until proven otherwise. Thanks for your help hack. It was getting late last night and I needed a sanity check and some sleep.
No problem with the torgue and thread depth concern I had. 80 ft-lb. Moving on.
