VERY unlikey that both motors are bad. If the passenger side switch is unplugged, neither side will work.
It is one of the most complicated window control systems I have run across.
Pull the switches and spray clean them with brake cleaner spray or MAF cleaner spray.
This will be a challenging repair. please keep us posted with your progress so I can edit and eventually place the thread in the FAQs section for others to use.
Thanx
