well i was planning on just using block off plates for the egr system so i dont have to worry bout any egr valve problems in the future, as for the head i'm getting it surfaced P&P and possibly everything replaced, and maby even mmm i think its called acid bathed.
7MGTE - 500hp never dyno'd
fidenza cam gears
