Thread: window and tach
Old 09-02-2007, 04:34 AM   #19
Supra2NR
Supra2NR's Avatar
UPDATE :
i just wanted to sum everything up since, i got on a thread good enuff for a sticky
so the tach
i used the black wire on the back of the gauge cluster, it is directly behind the tach, its the only black wire on the harness, its 6th to the right from the driverside of the car,
wired it up to the aftermarket tach and it works beautifully
the window issue, after checking all of them
its was the main power relay after all, but thank god i got a parts car,
so i replaced everything,
including,
the 7.5 gauge fuse
30A ciurcuit breaker
main power relay
and the main window switch
so hopefully this thread would be any help to anybody that might have the same problem
thanx to cre, and foogoo for ur patience and your help
