I havent seen anyone yet that has bought a 1JZ or 2JZ from JDM that has had a problem. 7M's are a older motor and yes the head gasket thing is a known problem. With somthing like a 7M yes I would do the top end before I dropped it in because you never know. Plus with a 7MGTE you can find one of those for like 800 bucks so with how little you paid why not do the top end.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
