Thread: I give up...
Old 09-02-2007, 05:56 PM   #1
EpilepticPuppy
EpilepticPuppy is on a distinguished road
Angry I give up...
I did a rebuild because I thought I had a bhg....while the head was off it was machined and milled at a engine shop. Put the thing back together, timing was done by a mechanic, and I have cleared out all the errors.
The problem is that when it starts it dies right away unless I give it gas. Then it won't stay started unless I keep it above 2k rpms. Is there anyway I could have put something back together wrong to make this anomaly not stay idle but still run at higher rpm?
I have changed the fuel filter. There is fuel pressure because I cracked open a bolt to see if it was torqued right, and it was.
I checked the vacuum hoses and they are all routed correctly.
I have tried kicking the tires.
I have tried talking nice to it.
But nothing seems to be helping.....Anyone have any suggestions before I take it to the dealer and give them a bag of money? If anyone guesses the problem correctly I will buy them a steak dinner, no joke.
It's an 89 NA supra exterior white with blue interior if that helps.
EpilepticPuppy is offline   Reply With Quote
