I thought a bigger turbo sucked in more air or volume of air, if the turbo uses a bigger wheel or turbine, fan or what ever you want to call it i thought a bigger turbo would give me more power do to sucking in more air, if that isnt the cause then why would they make a turbo upgrade,
Nr2 you need to empty your private msgs cause i cant send you anymore msgs.
