Ok, I think I understand what your asking about the rear calliper, they are the same as the front so I guess it would be a push in, but I might not understand what your asking.
On the front brakes, you are right, the calliper will not go all the way up, follow the brake line, on the other side there is a bracket, and two bolts holding it on just unscrew the bolts, 12mm I think, and you will be able to move the calliper out of the way, and for ease use a couple of zip-ties to secure the calliper up, it's a lot quicker that way. Hope this helps
