When you pull the motor out unplug the connectors to the ecu behind the glovebox. Push them through into the engine bay and pull the motor.
When you go to install the new turbo motor make all the connections and leave it on top of the motor.
Once the motors in feed the wires through the hole, install your new ecu right where the old one was and plug it in.
Nate
