Make sure that when you put the intake manifold back together you didnt get a bracket or something stuck between them because it causes a nasty vaccum leak. When you get it running like you said have someone give it gas and look to see if your exhaust manifold is glowing red that is a dead give away that it has a vaccum leak somewhere and it is running lean.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
