So Basically you could buy this
http://cgi.ebay.com/ebaymotors/92-95...QQcmdZViewItem
comes with engine, wiring harness, and trans.. So if you bought this then you would have to change the driveshaft, get new engine mounts (if its pre 89), intercooler, tubing, change power steering lines, Change A/C lines, Electric fan, water pump off the JZ2, and change the wirers in the dash, and the tach. Is this correct. Did i miss anything
