Old 09-06-2007, 02:28 AM   #13
abhattan
abhattan's Avatar
abhattan is on a distinguished road
Cool
If the sound is low pitched and slow, it is a rod knock. It will go away as the rpm's increase. If it is higher pitched (not too high) sound, then it is valve noise. The rod noise will also be a little slower than a valve noise because the bottom end of the motor moves slower than the top end. If it is in between and sounds more like a rattle, then it probably is the wrist pin. This also goes away to a degree with incresed RPM's. However, you will hear it most upon acceleration and deceleration. I believe it is either a rod knock or a wrist pin knock. These are the things that could go wrong in your cenario.
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Soon to be rebuilt (All to some extent)
abhattan is offline   Reply With Quote
