thought i would put the word out.
hey everyone i thought i would just bring up that if you have a shucks, or checkers automotive around you and you want a MAF adaptor to have a cone filter, specter makes them for the supra non-turbo, but other than that its 3inch, and use can use your stock air box to use a marker to mark were you need to drill your holes to fit the turbo. it cost 18.99$ and took me about 5 mins to make, it also comes with the sensor adaptor, and with a little dremel with a cutter blade you can make that fit also. take a look
i didnt have the adaptor for the sensor in this pic.
7MGTE - 500hp  never dyno'd
fidenza cam gears
