hard part, getting the auto out, easy part getting the 5 speed in, but altogether not that hard just a lot of strength, youll need a new speedo cable, clutch master/slave cylinder, clutch line, clutch and brake pedals, tranny driveshaft, flywheel, clutch, pressure plate, pilot bearing, release bearing, driver side wing bracket, inspection plate, 6 new flywheel bolts beginner wiring skills, and tach and ecu (last two are optional)
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
