Originally Posted by pwpanas
I'm sorry I don't quite understand your question. A downpipe will allow you to get to 'bpu' level with the oem twin turbos. This will allow you to run anywhere from oem boost all the way through 26psi. It's the boost controller (not the downpipe) that determines your boost level.
i mean do you think its a good downpipe for a supra TT? after looking at it at the shop i looked it up on the internet and this site says its suitable for a supra TT
http://www.killersupra.com/product.p...6&cat=0&page=1
What you ask here is a VERY complicated question. First of all, I don't know what "normal fuel" is in your city. Can you get 93 octane fuel, as rated using this formula (R+M)/2? Also, is 100 octane fuel available? If you don't have 100 octane fuel available, you can always use methanol injection together with 93 octane fuel, and still produce about 550rwhp or so with reliability.
well here they have all kinds of fuel, even 100 octane fuel, because this country is known for all the fuel it produces thanks to all the crude oil it has, which is good because fuel cost it quite low.
and i was thinking of some engine cooling accesories because out here its REALLY hot, i cant even emphasise how hot it is , what are your thoughts on this?
