ok so its all dissasebled heres some pictures of the havoc
thats a 6M crank in a 7M 87?
today i do the head im just waiting for my buddy with the spring compressor for the valves. my asian friend had the great JDM way of doing things, just cut the springs LOL. but so far everything block wise looked good, some of the bearings were scourched but thats why they are going to be replaced, and also i F#$#ed up and didnt keep the main crank cap bolts in the right order, i took them off in the right order but failed to put get them organized in the right order RRRRrr. so is there anyway to tell what bolt is what or do should i just get new ones that are most likely labeled?
and any suggestions on the parts list above and my questions would be helpfull at this stage so i know what all i should order
thanks
7MGTE - 500hp  never dyno'd
fidenza cam gears
