CPS, and make sure the harnesses to your coil packs are all hooked up, and then non the less check your engine bay relay box by the diagnostics for the ACC1 and ACC2 relays, i know if ACC1 is out the car wont start, it will just keep turning over.
7MGTE - 500hp  never dyno'd
fidenza cam gears
