ok so it just started to do this yesterday, it sounds like its missfireing or someone put some aftermarket cams in the car over night
weird idle
we checked the plugs - no problems
checked the injectors - when unplugging cylinder 4 injector clip, no difference in sound while all the others made the idle go down plugged it back in gave it some gas and WOO HOO white smoke out the ass, unplugged it again and pluged it back in no more smoke? whaa? it was sweet smelling and seriously looked like a BHG. and i wouldnt doubt it is since the car likes to over heat. i let the pressure out of the radiator while it was running the car started to idle fine.
i have to say though it sounds pretty bad ass in the morning when its cold, BLUB BLUB BLUB RRRRRRRRRAAAAARRRRRR
7MGTE - 500hp
never dyno'd
fidenza cam gears
