so what you know bout this
parts ordered so far
JE pistons 8.4:1 compression .020 bore
egale rods
Greddy timing belt + tensioner
HKS MHG w/stopper
ARP head studs
ARP Main studs
full engine gasket set
all bottem end bearings
water pump
oil pump
fuel pump
valve cover studs
hose techniques silicone hose kit
RC 750cc injectors
lexus MAF
FCD
greddy upgrade turbo
FIDANZA ALUMINUM FLYWHEEL
oh cant forget the TRD OIL FILTER WHA WHA TRD ALL THE WAY!!
there is more i just cant think off the top of my head everything, the head will be getting parts ordered next week maby so.
in the process of the block being tested, surfaced, and bored
still in process of dissasembling the head for surfacing and P&P
ill be getting pics of the rebuild as i go along so ill try to keep everyone posted.
7MGTE - 500hp
never dyno'd
fidenza cam gears
