Originally Posted by tdubz04
...what for? i have zero issues running 18 psi... no knock, no pulled timing, nothing i know a guy who was running 20psi on pump gas with just an octane booster.. again zero issues.. there are people out there that run over 20 psi on pump gas... why would 18psi need race gas?.. but thanks for the compliments...
If you were running an unmodified oem ecu, your OBD knock logs would show differently. So would before and after compression results. Its possible your g-Force ecu has a non-oem timing curve, which could allow you to run 18psi safely with 93 octane pump gas. Keep in mind not everyone has a gForce ecu, so running 18psi on pump gas is generally bad advice. Either way, best of luck.
