09-15-2007, 12:52 PM
#3
Supra Owner
Originally Posted by sentra_tt
how much would it cost if i wanted to do the 2jzgtte swap to a N/A supra????!?!??! ...................and what other parts would i need then below?
i know i can get the 2jzgtte for $1900 motor,tranny, manifolds, turbos, mounts, ecu, harness,fuel rail, sensors, injectors, throttle body, CAS, and aternator
If you can get everything you need (from a SUPRA, not an Aristo, for example), and it's all in good working condition, then simply pull the old n/a parts out and put the new TT ones in. Probably about 12 hours of labor for everything...
Life begins at 30psi.
