the block is now surfaced, been pressure tested, and bored .20 over
so far the parts recived are
.20 stock pistons/wrist pins/clips/seals
Eagle rods
full gasket kit
Greddy timing belt
Timing belt tensioner
EGR block off plates
Hose techniques hose kit
Parts still waiting on are
ARP head studs/nuts
ARP main studs
HKS HG <not stopper :,~(
TRD oil filter
valve cover studs
sheet metal < to weld over that damn EGR cooler plug
NGK irradium XI
NGK 7.5mm wires
toda valve springs and retainers
brian crower valves
cams / webb racing cams
full bearing kit
uhhh well there is probably more but thats all i could think of off the top of my head
PICTURES
7MGTE - 500hp
never dyno'd
fidenza cam gears
