Originally Posted by Syris
Yes there is a linkage on the side that you should be able to see while still in the car IIRC. Check your fuses for any blown ones as it might be causing to not want to shift. But have a friend shift from Park to neutral while you are under the car to find exactly which linkage to move.
Thanks, i will give it a shot.
