because, its blue and says greddy :P why does everyone else choose the greddy belt over the OEM, i was guessing cause the greddy may be stronger and can probably can handle more HP than the OEM before it snaps or slips, neither is good. and did i mention its blue and says greddy
7MGTE - 500hp never dyno'd
fidenza cam gears
