that kind of seems like alot, that motor is out for a reason. If you know how to do it, you might want to pull the head off, shouldent be to hard if its on the ground, and make shure the motor is not cooked, and the head is not cracked
if the guy that is selling it says you cant crack into the engine then i would not buy it. good luck
