radiator - couple hundred depending on oem or aftermarket
headgasket - maybe 1000 or more, go metal headgasket, arp studs and higher torque, machine the block ect.
brake lines - 100 plus for ss braided
gas lines - probably the same as brake
good luck, to me if you want more power, its not worth it to rebuild and na unless its strictly used for a daily driver
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
