It's possible the little button he's describing has broken off. I had that problem recently and to fix it I got a plastic press fit rivet to go in the hole to make up for the gap the old button would fill in between the brake arm and the brake light off sensor. Do some back stretches and get a bright flashlight to look under your dash to see what we are describing.
