Originally Posted by kevo
Thank you PWPANAS,...For your reply....Looks like i need a new oil pump me thinks...
You're welcome.
I hope it's not the oil pump, but if it is you'll likely have to pull the engine to change the oil pump. The oil pump is actually behind the oil pan in a couple of areas, so there's no way to swap the oil pump without removing the oil pan. There's almost no room to pull the oil pan off unless you pull the engine.
It actually can be done without pulling the engine, but only with great difficulty. Most that have tried have come to the conclusion it would have been easier to pull the engine. Be sure to use the
TSRMs when doing this work.
