ok so i have got a new turbo ordered
specs
greddy GT 45
Compressor Wheel - .66 A/R, 48.9 trim Turbine Wheel - 1.05 A/R, 61.9 trim 4.25" inlet, 3.38" outlet T4 flange with V-band
now i have a question about the v-band, since its not a straight bolt up to the DP what would i have to do to get it attached, do i just cut off the DP flange and put a v-band adaptor and get a v-band clamp? heres a picture
so what you all think, i'm also getting the aftermarket headers w/ 40-50mm wasgate flange and t4 flange. peak boost for this turbo is 35psi max 600hp
7MGTE - 500hp
never dyno'd
fidenza cam gears
