are you bleeding it with the slave cylinder removed from the tranny? if so then yeah it wont come back up, but when you bolt it on the fork will force the piston back into the bore of the slave cylinder and the fluid will push the pedal back up
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
