Old 09-25-2007, 05:52 AM   #10
teedoff00
teedoff00's Avatar
teedoff00 is on a distinguished road
From what I have research, na cams in your 7m-gte are good for a few ft/lbs and even some horse power, but they wont withstand the abuse if you are running alot of boost or are aiming to hit high numbers, ie. over 300-350 horse. So if you are pretty much stock, then you will probably notice a nice increase, if you are looking for a reliable high horse power build stay away. Also make sure the cams are in good shape or you might risk jacking your valves as well as you guides, that could get pricey...
teedoff00 is offline   Reply With Quote
