i have a bhg but no milky oil but theres exhaust gasses in my radiator, if youre topping off your radiator every now and then you should check for a bhg, and about that leak it may be leaking so much that your cooling system is losing enough water to the point where theres not enough to keep cool
revving the engine increases the fan speed so it blows harder therefore more cooling
and is the water in you overflow tank boiling and blowing out steam? and is your coolant a normal color or brown?
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
