Old 10-02-2007, 09:04 PM   #1
IHateHacks
IHateHacks's Avatar
Run a block test to rule out a blown head gasket. Then pressure test the cooling system. Your overheating vehicle will fail one of these 2 tests.
If you really think the thermostat is bad, change it. They are cheap and easy to do on a 7M. Then take the one you took out and boil it in a pot of water and see if it opens, then you will know for sure if the thermostat is bad or not.
A stock cooling system holds about 9 quarts. Its 8.6 for an 87 non turbo 5spd
