Thread: 2jz swap
Old 10-03-2007, 10:04 PM   #2
supradaddy0803
supradaddy0803's Avatar
I payed like 1900 for the whole clip with my 1JZ and the 1JZ was actually made for the mark 3 so it is much easier to put in. The thing is with what you are looking at is just the motor ecu and wireing. there is gonna be like a grand more of stuff that you will need to get and it going to be hard to find. Easier to get a clip and then you get all the parts you need to get it all done. If you lived close to me I would take you for a ride in my car and you would see hauling butt. Plus the 1JZ has a lot of interchageable parts with the 2JZ so parts arent that hard to come by. Check driftmotion they have them in stock and look at the difference in what you get.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
