so your going by the boost guage in the dash correct? if so it tops out at 8 psi and will just pin to the top after that. you need an aftermarket boost guage so you know exactly how much boost your putting out, espicially if you've already raised the fuel cut with the lexus afm and 550 injectors cuz you don't want to harm your engine.
