Originally Posted by df963
This option appears much cheaper at the moment.
Cheaper than what? Purchasing an n/a and then upgrading everything to TT? If so, then yep I agree 100%. In fact, it's even cheaper if you might go single turbo on the Supra someday, because you'll already have the header and the downpipe! Just be sure to confrim with the Aus. gov't that buying a TT and removing the turbos qualifies the car as non-turbo from their perspective.
Auto TT Supras are selling for $2000 more than N/A.
The auto TT seems like a MUCH better deal than the n/a.
All I would have to convert the transmission sometime.?
Why? What will be using your Supra for? If you'll be drag racing it, the auto is faster and more consistent...
You couldn't send it over to Australia could you?  Do you have any idea where to get those parts (in Australia)??
The bad news is that a brand-name (eg. HKS) single turbo header and downpipe will cost about $2500 USD or so. I've heard you can get them on ebay but the quality is somewhat suspect...
Roughly how much would a job like that cost?
Probably more than $10K USD.
Also, if I had say put in an aftermarket stereo system and that, would that make it harder to do the conversion?
No, it'd make the job easier. Converting to an exact oem TT stereo would be somewhat tedious - finding specific oem parts like wiring harnesses and oem subwoofer enclosures, etc. An aftermarket stereo usually bypasses some or all of the oem wiring, and the oem components are completely replaced.
