Old 10-14-2007, 11:41 AM   #2
IHateHacks
IHateHacks's Avatar
You might be getting a different reading because oil pressure varies throughout the engine. You should replace the stock oil pressure sending unit with the gauge you bought, compare your readings, and use that oil passage for an oil temp gauge.
