The max boost on the stock Ct26 turbo is about 14psi, but teh turbo probably wont last much at those boost levels. So i would go a little lower If i were you. And also placing 2 shims wont get you 14 psi, youd need longer bolts to get that high.
MK3, Auto, Turbo.
