Originally Posted by supraman121
This is on your stock struts? What type of struts do you have? And were did you find 2.5" lowering springs i cant even find 2" anymore?
its not on the stock shocks,
i got kyb shocks, and idk about the srpings
i got it from a friend of mine paid 100 bucks for all four
imma go try to figure that out when i get the chance
probly tuesday the earliest
Replacing struts on a MK3 is far from a puzzle, its actually one of the easiest vehicles to lower, if you don't believe me go try lowering an 80's chevy.
All you need is a 19mm socket, 19mm wrench and a big fuckin breaker bar at least 2 feet long. In the front you need to unbolt the upper control arm by taking that long ass bolt out. Have fun extracting it, as the whole wheel well is built around that bolt. The rears are very simple, just unbolt the strut and wrestle with it for a while, should not take you more than 1 hour for the rears and maybe 3 hours for the fronts.
oh it wasnt a puzzle jus a bit of a b***h if you dont have the right tools
2hr 45min took me for the front , and 47mins for the rear, i timed myself when i was doing mine
